Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HID on third gen focus, WITH DRL
Old 01-27-2013, 01:55 PM   #11
klotche
klotche's Avatar
Fan#: 91834
What I Drive: 2012, Oxford white, Focus
Points 5,854, Level 49
Points: 5,854, Level: 49 Points: 5,854, Level: 49 Points: 5,854, Level: 49
Level Up 52% Completed
FF Reputation: 3 klotche Good Standing Member
Originally Posted by Graeme S View Post
I was just turned on to that by a friend of mine who did his retrofit a little while ago. I got in touch with Andrew, and am having a bit of back-and-forth with him discussing different options.
Canadian cars come standard with DRLs (law since '89) and usually it's the highbeams on reduced power. My car's in the shop at the moment 'cause I got rear-ended by an X5 two days ago, so I can't just walk out and check--is it the same for the Focus? If not, I may ask my buddy to see if he can rewire the fogs to just always be on whenever the car's running.
No it's not, Focus mk3 uses DRL on low beams, at a reduced voltage (9 volt)...
Easiest way for me was to add a relay harness + resistor... I did wire a switch on my relay harness that goes to the interior of my car, like this I can close ALL lights, and all power is sent to my resistors. When i open this switch, i get my low beams (HID). I never get bulb out error cause of resistor, and i can control my lights like I want (only low beams, only fogs, or both). It's my way of by-passing those DRL
klotche is offline
