Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No 4th gear
Thread: No 4th gear
Old 01-26-2013, 07:14 PM   #8
Fan#: 109123
What I Drive: 2002 protege 5
FF Reputation: 1 Endless Good Standing Member
I inspected the rear cover and the ring seat looked fine, replaced the rings that came with the kit. I did not measure the ring seats so i cant confirm there was no wear. The molded piston in the drum looked good along with all of the other pistons.
Manually shifting has the same problem, no 4th. Not sure how the focus manually shifts but on the protege you move the shifter to the manual position and forward for down band backwards for up. This is all electronic and not linkage shifting.
I didnt have a band select guage so i reused the bolt and adjusted it by feeling the band tension with the valve body removed and welding the tip of the bolt to make it longer. I had to add 1/16" to get the tension right.
I was guessing pressure loss too. Any ideas on trouble shooting that?
I was hoping i could pull the cover by tilting the trans down. Thanks for confirming that
Endless is offline
