Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SS brake lines for 08+ with SVT brakes?
Old 01-26-2013, 06:24 PM   #7
PowerFocer
PowerFocer's Avatar
Fan#: 61706
What I Drive: 2010 Sedan SE
Points 4,602, Level 43
Points: 4,602, Level: 43 Points: 4,602, Level: 43 Points: 4,602, Level: 43
Level Up 26% Completed
FF Reputation: 2 PowerFocer Good Standing Member
Originally Posted by jonny.burns.g1 View Post
You have to use the beak lines from an svt on your car. The front lines are entirely different as in our stock lines don't go onto the front of the svt calipers. Rear lines are solid and need a bracket and flex for the movement of the caliper. I've don this swap on two different 08+ cars its easy... Just use stainless lines meant for an svt I don have stainless lines just stock lines from an svt and they fit as they shoul after you swap out the banjo style fitting on the 08+ fronts.
So the stainless lines meant for an SVT will swap straight on?
Rule of thumb:
NEVER trust anyone with your car or your girl.
Either way, you could get a rod thrown in both.........
Fast cars make smart people do dumb things
PowerFocer is offline
