Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Valentine One
Thread: Valentine One
Old 01-26-2013, 07:15 PM   #35
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by zolemite View Post
For Rat:
These are the two plugs all the wires are coming off of. On old cars all the wires were directly behind the fuses. If you push the tabs on the bottom you can move the box around and see the back. There are no wires visible. Therefore before you could just look behind the fuse and you could see what color wire to splice into.
You can see the plugs on the other photo. These are the wires you would "tap" into.
I can't tell which plugs these are. The ST guys said look for a white wire with a brown stripe. I'm having a hard time finding this.
Right now, I have an add-a-fuse, but it turns the detector off after ~30min, I'd rather it turn on/off with ignition (hence tapping the wire).
Can someone post better pics of the wire I'm looking for?
thejordan is offline
