Old 01-26-2013, 04:28 PM   #1925
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by jsr72 View Post
Wheel end motion is accommodated by plunge within the inner cv joints. The halfshaft can slide laterally inside this joint housing. It can also articulate in angle.
This is needed for steering because the outer cv joint center isn't completely coincident with the steer axis. It is also needed for suspension travel because the arc of the wheel end motion isn't centered on the inner cv joint center. It is also needed to accommodate movement of the powertrain on its mounts.
Okay that makes sense if the CV joint is allowing for this change at the wheel.
So the CV could be a likely candidate for the clunking sound? I'm wondering if the CV part of the axle is what they changed from '12 to '13 resulting in different part numbers then.
I'd like to see someone put in a '13 axle in their clunking '12.
thejordan is offline
