Old 01-26-2013, 02:35 PM   #1922
revhigh
Fan#: 98516
What I Drive: 2012 Mazda 3 SkyActiv 6A Touring
FF Reputation: 1 revhigh Good Standing Member
Originally Posted by thejordan View Post
Lateral play when you pull on the wheel? I still don't think so. Maybe if you disconnect it from the hub assembly and get the play, but not while everything is attached. The wheel shouldn't move.
If the car were suspended on a lift with the wheels free, you can generally get some lateral play by grasping the halfshaft and moving it in and out of the trans slightly. Never seen one NOT like that.
OR ... if you move the wheel up and down while it's on a lift, you'll see the halfshaft move in and out of the trans slightly. IT has to be like that ... if there were no play, up and down movement of the wheel on the road would pull it out of the transmission.
If you've ever replaced a half shaft ... you'd see what I mean. There is play in the splined area BEFORE it hits the retaining ring.
REV
revhigh is offline
