Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2002 ford focus won't start? Crank angle sensor or upstream oxygen sensor?
Old 01-25-2013, 09:59 PM   #10
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,284, Level 100
Points: 31,284, Level: 100 Points: 31,284, Level: 100 Points: 31,284, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Seem to be getting?
Originally Posted by Lovelyvanity View Post
Throttle was perfect after. Here's a pic of how #4 on the coil pack looked. Changed the coil pack crank position sensor checked timing changed plugs. Engine still first seem to be getting spark.
"Seem to be" is a red flag for me, it's something that needs to be tested to a firm conclusion, yes or no.
There are tools to test for spark, yet the simplest is to take the plugs out then connect them to their wires & lay them on a grounded metal surface & crank the engine (helper needed) so you can look for the spark at the plugs.
The valve cover is NOT grounded (supported by rubber gaskets) so find another handy spot!
Jumper cables are great for this, though car size are a bit unwieldy....
Cheers!
sailor is offline
