Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Adding fog lamps?
Old 01-25-2013, 09:18 PM   #52
Monkeygrits
Fan#: 47691
What I Drive: 2013 Focus SE Hatch
Points 466, Level 9
Points: 466, Level: 9 Points: 466, Level: 9 Points: 466, Level: 9
Level Up 32% Completed
FF Reputation: 1 Monkeygrits Good Standing Member
Actually I think It may have only taken 2 weeks to receive the bezels. Ill edit that post.
Heres a pic for reference. Not mine. This add a fuse is in the 7.5 Amp slot. I used the 10AMP fuse slot directly below it. Its hidden by the fuses sticking out the add a fuse in the pic. Gives you an idea how it looks. You have to pull off the trim around the shift boot off before the ebrake trim piece. There is a bolt under the shift boot trim piece that needs removed plus the shift boot trim snaps into the ebrake trim piece. Do yourself a favor and go to Harbor Freight or a cheap parts store and buy a set of trim tools so you dont gouge all your trim. (Click the link below) Dont use flat screwdrivers!
http://www.harborfreight.com/5-piece...set-67021.html
2013 Ruby Red Focus SE Hatch
2009 Vivid Red Mercury Mariner Premier
2003 Azure Blue Mustang Mach 1
Monkeygrits is offline
