Old 01-25-2013, 10:16 PM   #1910
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by thejordan View Post
Wait, your axles should have 0 play in them... they should only rotate, not wiggle. This may suggest center diff problems or some other onslaught.
The cv boots are loaded with grease, this heats up as use increases.
EDIT: comprehensive list, refer to all TX-____ part numbers.
apparently they are different part numbers for 2012 models and 2013 models.
2012 models:
3B436
(TX-565)
CV Joint Axle Shaft Assembly
5-Speed Manual Trans - MTX75 ; RH
$276.80
Vehicle Build Date before: 12/14/2011
3B436
(TX-566)
6 Speed Auto Transmission DCPS ; RH
$266.38
3B436
(TX-639)
$223.38
Vehicle Build Date after: 12/15/2011
3B436
(TX-640)
$222.06
3B437
(TX-568)
5-Speed Manual Trans - MTX75 ; LH (Left)
$179.06
Vehicle Build Date before: 12/15/2011
3B437
(TX-569)
6 Speed Auto Transmission DCPS ; LH (Left)
$182.46
3B437
(TX-641)
$144.36
Vehicle Build Date after: 12/16/2011
3B437
(TX-642)
$147.16
2013 models:
3B436
(TX-565)
$276.80
3B436
(TX-566)
$266.38
3B436
(TX-639)
$223.38
3B436
(TX-640)
$222.06
3B437
(TX-568)
$179.06
3B437
(TX-569)
$182.46
3B437
(TX-641)
$144.36
3B437
(TX-642)
$147.16
thejordan is offline
