Old 01-25-2013, 09:08 PM   #1909
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by Lipshurt View Post
The only thing I've found that makes he sound and I have NOT ruled out is the play in the driveshafts/cv joints. Jiggling those side to side makes the exact same sound. How would those respond to heat? My thinking is that they wound heat up slow, cuz they get heat from the ends of the shafts. From both ends (brakes and tranny). That would explain how long it takes for the sound to go away when heating up. It also explains the fact that when it is making the sound I seem to be able to feel play in the wheels, or get the vibe that the wheels are loose.
Wait, your axles should have 0 play in them... they should only rotate, not wiggle. This may suggest center diff problems or some other onslaught.
The cv boots are loaded with grease, this heats up as use increases.
thejordan is offline
