Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Timing Belt Change?
Old 01-25-2013, 08:13 PM
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 399, Level 7
Points: 399, Level: 7 Points: 399, Level: 7 Points: 399, Level: 7
Level Up 98% Completed
FF Reputation: 2 150mphzetec Good Standing Member
Originally Posted by 2000Sr View Post
I had a zx2, which had the VCT on the exhaust side, I have changed timing belts on the cars with ease, I would rotate everything with the factory belt on to TDC set the bar in the back of the cams, and then remove the belt and re-install the new belt and tighten the adjuster.
My Question is, My SVT will need a belt shortly, my question is, could I rotate it all to TDC set the bar in the back and then remove the belt and re-install the new belt and tighten the adjuster?
If I am reading this correctly, you are assuming the car is on TDC when you turn the engine and lock the cams in place. All this does is make sure that the cams are locked in place. This does not ensure the that #1 piston is actual TDC. You really need to use a crank locking tool. Unlike the ZX2 zetec, the zetec in the SVT is an interference engine.
150mphzetec is offline
