Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "cylinder 1 misfire" code
Old 01-25-2013, 08:08 PM
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,635, Level 100
Points: 31,635, Level: 100 Points: 31,635, Level: 100 Points: 31,635, Level: 100
Forum Activity 100%
As whynot hinted, just what the plug looked like B4 being cleaned is critical information for diagnosis.....
(so is a compression check)
As to "guesses", the coil and it's connector pigtail are common issues - followed by plug wires & their connections. "Cracking" of the coil, especially in the base area that can only be seen after removal, is indicative of an issue there. Inspecting the coil connector & it's wiring is always a good idea on these, there's a reason a replacement "pigtail" is available from Ford....
Speaking of "tests", I like to do a quick check for spark with a neon spark tester, either an in-line model or the cheap & quick AC brand pocket pen tester that you only need to hold to the wire to see if you have a good jolt of electricity moving through it!
Luck!
sailor is offline
