Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2009 intermittant heating problems
Old 01-25-2013, 08:56 PM
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,504, Level 99
Points: 29,504, Level: 99 Points: 29,504, Level: 99 Points: 29,504, Level: 99
Level Up 70% Completed
Forum Activity 100%
Blend door issues are the MOST common cause of your issue, IF you can confirm that the door is in the proper position when you don't get proper heat the next check would be to backflush the heater core to remove any "crud" that may be intermittently blocking it.
Checking for decent flow when you do it....
A cheap infrared thermometer would help confirm the heating issue quickly, failing that I've had good luck checking A/C operation by just putting a small kitchen (cooking) thermometer in a dash vent. That would give you some numbers to work from that would confirm things better than how it "feels", since varying outside temps have a LARGE effect on subjective estimates of temperature....
Luck!
sailor is offline
