Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Hard Plastic Door Panel
Old 01-25-2013, 01:11 PM   #5
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 1,502, Level 22
Points: 1,502, Level: 22 Points: 1,502, Level: 22 Points: 1,502, Level: 22
Level Up 2% Completed
FF Reputation: 5 dbenney Good Standing Member
i use to work on the Focus door line and I can tell you that there is no difference in the door, jsut the electronics, wiring and panel. a SEL inside door panel will fit correctly with no issues. Cost from a dealer will be a bit high. the best bet is to start looking for a wrecked car in a salvage yard.
They look separable because a door panel is actually several molded pieces sonic welded together. I also worked in a plastic parts plant where we made door panels. Is it possible to replace... yes, is it a lot of work and hard to do at home without proper equipment... yes. like i said jsut find a wreched car and get whatever you want out of it.
dbenney is offline
