Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Adding fog lamps?
Old 01-25-2013, 12:14 PM   #49
Monkeygrits
Fan#: 47691
What I Drive: 2013 Focus SE Hatch
Points 466, Level 9
Points: 466, Level: 9 Points: 466, Level: 9 Points: 466, Level: 9
Level Up 32% Completed
FF Reputation: 1 Monkeygrits Good Standing Member
Finished installing my foglights. Kind of a PITA but I think it turned out great.
First 2 is the button switch mounting location. This is the only place I found on this trim piece to mount it where there was enough room behind it for the switch and wiring. I wanted the switch mounted on a removable trim piece in case I ever wanna go back to stock, I could just replace that piece. Kinda nice too because the Ebrake handle blocks the light at night from shining in my eyes. These switches are awesome and worth every penny.
If you look at the bolt to the right of the gas pedal, you can see where I found a good ground for the switch. Easy to get to as well.
Front shot. Its amazing how much salt Mayland uses on their roads. I washed it off when I was done. Didnt want to lay on a wet floor. Black bezels are from China and are as good a quality as the covers I took off. Plus they are only around 20 bucks shipped. Only issue is they take 2 weeks to get. Im on the east coast. Farther west may take longer.
Heres where I mounted the Relay. Great place as its out of the elements and easy to get to. Plus theres a ground right beside it. The green wire running around the fusebox is the wire that goes to the switch. I extended it with black wire. You can see it zip tied to the loom of wires on the firewall in the next pic.. I had to run it to the pass side and make a small hole in the rubber grommet around where the loom goes through the firewall into the cabin. I put the in line fuse for the relay in the battery box.
Power for the switch I didnt take pics of but its been covered before on here. Under the glovebox, I used an add a fuse in a 10 amp fuse slot controlled by the ignition. Far right row, 4th fuse space from the bottom.
2013 Ruby Red Focus SE Hatch
2009 Vivid Red Mercury Mariner Premier
2003 Azure Blue Mustang Mach 1
Monkeygrits is online now
