Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - anyone using premium gas ?
Old 01-25-2013, 09:35 AM   #11
mishka
mishka's Avatar
Fan#: 107408
What I Drive: 13' TB SE Sport Sedan DCT 201A pack
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 4%
FF Reputation: 1 mishka Good Standing Member
Most of the time if you stop even if you stop fairly abruptly it won't do that, only if you were really going and then suddenly stop, something I try not to do normally and the engine was wound up in lower gears it seemed to hold onto the engine speed longer than absolutely necessary.
I think I had finally managed to run into a use case that more people may see more often, which is a sign that they are typically abusing the vehicle most of the time as that had not happened before or since.
ok so you're saying that if one notices higher reving then normal after stopping, and they had not stopped abruptly, then they are abusing their car?
~ Shadowfax ~
169.5 whp; 156.5 torque - dyno'd 11/22/2014
mishka is offline
