Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cam Timing Tools
Old 01-24-2013, 05:09 PM   #7
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.1L ITB Zetec)
Points 498, Level 9
Points: 498, Level: 9 Points: 498, Level: 9 Points: 498, Level: 9
Level Up 96% Completed
FF Reputation: 2 GhostTribute Good Standing Member
If it is the same as the ZETEC TDC procedure. I found it pretty easy and cheap to buy some flat bar stock that is 5mm thick. Then buy an M10 x 70mm full thread bolt and 2 nuts. Measure 63.4mm from the tip of the bolt and that is where you lock two nuts together. This would allow only 63.4mm of the threaded bolt inside the block. This will hold the crank at TDC.
GhostTribute is offline
