Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Disassembly for grill
Old 01-24-2013, 05:56 PM   #2
sgmfocus
sgmfocus's Avatar
Fan#: 101095
What I Drive: 2012 sgm sedan se,sfe package
Points 293, Level 5
Points: 293, Level: 5 Points: 293, Level: 5 Points: 293, Level: 5
Level Up 86% Completed
Level up: 86% Level up: 86% Level up: 86%
FF Reputation: 3 sgmfocus Good Standing Member
you don't have to take the grill out the two plastic chrome pieces can be removed this is how i did mine,have to be careful, there a real pain to get out, there glued on top side, use a wrapped screwdriver or trim stick if you have one,there are three tabs on bottom and two on top,
start prying on one side with other hand lift the bottom tabs/clips up when there all free bottom will lift up then you can pull the top out you may have to cut or loosen the glue
sgmfocus is offline
