Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - CEL P0171 (BANK 1) help
Old 01-23-2013, 10:32 PM   #3
focusSE2002
Fan#: 108993
What I Drive: 2002 Black SE
FF Reputation: 1 focusSE2002 Good Standing Member
Originally Posted by sleepyboy View Post
Welcome to the forum
Did you have a shop install the engine? If so take it back and tell them what's happening. If the oil light is coming on that's not a good sign, neither is the ticking your hearing if it's having that light. Check for vacuum leaks and use a screw driver to hear where the noise in coming from. The motor you got could be bad. It could be running lean from a leak or maybe the front O2 sensor might need replacing. We tend not to recommend putting another SPI motor in and usually point towards doing a zetec swap.
Thanks! well i got a used engine and had a shop put it in, although this light is present and pretty much stuck, I really just planned to sell the car unfortuantly :/ but i wont get much in the condition its in although its probably just minor
i did see the one of the intake manifold nut or bolt was loose just now
focusSE2002 is offline
