Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Idle Saga Continues...
Old 01-23-2013, 07:46 PM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 33,119, Level 100
Points: 33,119, Level: 100 Points: 33,119, Level: 100 Points: 33,119, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Originally Posted by rycodge View Post
Again, if I disconnect the IAC valve, the car runs great and idles just as you'd expect a car to idle at.
That's a good sign that the IAC is bad. I usually recommend people remove the IAC, and clean it before purchasing a replacement. Afterwards, reset the A/F ratio by first warming the engine up by driving around, then disconnect the battery for 10 mins or so. Reconnect the battery, and start the engine. The idle should go up, then settle around 1k rpm. Allow the engine to idle for 5 mins without touching the accelerator. During this time you might notice slight fluctuations in the idle- that's normal. Once the ECU is done with the A/F test, the idle should settle around 700 rpm. That should fix it- if the IAC is not damaged.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
