Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Running Out of Patience
Old 01-23-2013, 10:50 AM   #4
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 3,182, Level 34
Points: 3,182, Level: 34 Points: 3,182, Level: 34 Points: 3,182, Level: 34
Level Up 88% Completed
Forum Activity 4%
FF Reputation: 18 elsolo Great Standing Member
Airbag light:
-check fuse F60 (7.5amp) behind dash on left side near your left knee. That powers the module under the console. There is also a ground wire down there for the other side of the power circuit.
-The "clockspring" in your steering column will throw airbag warning light if it has gone bad. It is a thin printed circuit on flexible film, it's appearance is like a wound clock spring.
-There are sensors to see if you are sitting in the seats
-There are sensors to see where the seat position is
-There are sensors to see if the belts are buckled
-There are wires going to the seatbelt tensioners
(if any of those sensors is disconnected or has a broken wire, warning light will come on)
elsolo is offline
