Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - bad svt problems!!!HELPPP
Old 01-22-2013, 09:28 PM   #17
02svtf1326
Fan#: 76507
What I Drive: 2002 silver svtf zx3
FF Reputation: 1 02svtf1326 Good Standing Member
Originally Posted by 1turbofocus View Post
Things that would make it hard to crank and make the header glow at idle
To little fuel or to much fuel ( this can be checked with a fuel psi gauge and a scan tool)
To little or to much ignition timing ( this can only be checked with a scan tool)
Cam timing off ( this can be checked by setting the cams and #1 Cly like your going to install a new timing belt )
Vac leak but this would also cause a very high idle , like above 2500rpm (this can be confirmed with a scan tool or checking every vac like for issues , this I do not feel is your issue)
I have never seen a CAT cause a hard cranking or a header to glow until you put a load on the engine
I think he is either running very lean , overly rich and burning the fuel in the header(rare) or has a valve open when it shouldn't be from cam timing issues , these are the most common then it gets complicated
Tom
I will have to check into these! Thanks! And my battery is new...it doesn't turn over slow it just takes awhile to fire up! Would a blown intake gasket cause any of this?
Hatch Nation #31
02svtf1326 is offline
