Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - IAC valve plunger.....
Old 01-22-2013, 09:24 PM   #3
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 4,058, Level 40
Points: 4,058, Level: 40 Points: 4,058, Level: 40 Points: 4,058, Level: 40
Level Up 54% Completed
FF Reputation: 11 emsvitil Great Standing Member
The ford IAC's use Pulse Width Modulation (PWM) to vary how far the plunger opens.
If 12 volts fully opens the plunger 6 volts will open it halfway. With PWM of 50% on, 50% off, the solenoid thinks it's getting 6 volts.
The ECM varies the PWM to open/close the IAC, and remembers where it was before as a starting point.
I just want to know if partially open is the starting point........
I get about 1/8" of travel from the starting point to fully open. (or as open as it's going to get).
If that's correct, I'm good. The plunger doesn't seem as sticky as when I started, so I may be fine now............
Ed
emsvitil is offline
