Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Cranks but no Start
Old 01-22-2013, 06:46 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,866, Level 100
Points: 32,866, Level: 100 Points: 32,866, Level: 100 Points: 32,866, Level: 100
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
When you replaced the coil pack, did you inspect the plug-in connector? Pull on the wires going to the coil pack. Sometimes those are damaged. Also check back about a foot or so and look in the harness for damaged wires. I'd also check anywhere in that wiring loom that is near something hot like the EGR feed tube. We've had a few SVT owners that found damaged coil wiring back about 2' from the coil, but most of the time the wires will simply pull out of the connector. If that's the case, then you need a new pigtail. Any Ford dealer can get you the part.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
