Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - bad svt problems!!!HELPPP
Old 01-22-2013, 03:50 PM   #16
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT Turbocharged
Points 68,210, Level 100
Points: 68,210, Level: 100 Points: 68,210, Level: 100 Points: 68,210, Level: 100
Forum Activity 99%
FF Reputation: 158 1turbofocus Excellent Standing Member 1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (29)
Things that would make it hard to crank and make the header glow at idle
To little fuel or to much fuel ( this can be checked with a fuel psi gauge and a scan tool)
To little or to much ignition timing ( this can only be checked with a scan tool)
Cam timing off ( this can be checked by setting the cams and #1 Cly like your going to install a new timing belt )
Vac leak but this would also cause a very high idle , like above 2500rpm (this can be confirmed with a scan tool or checking every vac like for issues , this I do not feel is your issue)
I have never seen a CAT cause a hard cranking or a header to glow until you put a load on the engine
I think he is either running very lean , overly rich and burning the fuel in the header(rare) or has a valve open when it shouldn't be from cam timing issues , these are the most common then it gets complicated
Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance!
Customer Support
AIM: hpdyno
Email:
Phone: 704-249-3745
Site:
Elder 1turbofocus
1turbofocus is offline
