Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - quick question
Thread: quick question
Old 01-22-2013, 12:06 PM   #12
Justinr666
Justinr666's Avatar
Fan#: 96239
What I Drive: 2009 Dark Blue SES Coupe, 5speed
Points 652, Level 13
Points: 652, Level: 13 Points: 652, Level: 13 Points: 652, Level: 13
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 2 Justinr666 Good Standing Member
Originally Posted by Duhamel View Post
Baldurs,
Did you remove the grille from the full piece with the honeycomb/mesh part? As in, you only had the part with the two bars and logo to tend with? Just asking. All I used was cheap grey primer, 3 coats, and Dupli-color black, 3 coats, and put each coat on while the other was slightly tacky (5-10 minutes), which was after sanding the entire surface with 360 grit and wiping it with a tack/tacky cloth. The only issue is re-attaching the grille. I had to use 3m double-sided "tape". You can easily see the bolt that holds the logo on when you have it separated from the honeycomb/mesh part.
Mine's held up for over 8,000 miles/12,000 kms with barely any chipping, and it was chrome to begin with.
Edit - I also prepped and painted my fog bezels and chrome accent rings with the same process and color, which is holding up even better than the grille. I can't stand the flat black plastic crap.
you do need to separate the grill to do that... i took my logo off
o paint the grill while leaving the honey comb on. so its not necessary to remove it to take the logo off
Justinr666 is offline
