Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Suspension Upgrade
Old 01-22-2013, 09:14 AM   #26
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,854, Level 32
Points: 2,854, Level: 32 Points: 2,854, Level: 32 Points: 2,854, Level: 32
Level Up 70% Completed
FF Reputation: 27 Zillon Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by Benson2020 View Post
I am wondering if there is a reason you went with Koni yellows instead of ST rear shocks. Can I use ST shocks for the rear or do you recommend the Konis? I want to order my suspension this week and would like I go ST all around (shock part # anyone?) but will go with Koni shocks if that makes more sense. What do you recommend?
ST rear shocks won't fit.
Ford altered the rear suspension of the ST to fit a full-width sway bar. In doing so, they changed the rear bearing carrier entirely, so that the shock mounts to the top instead of the bottom. The ST shocks are about 7-8 inches too short; I found this out the hard way.
Mazdaspeed3-fitment shocks, however, are a perfect fit.
The reason I went with Konis is because of the rebound adjustability they offer. It afforded me the ability to fine-tune the setup to match the damping of the ST front struts as best I could. Overall, I was very satisfied with the setup in terms of ride quality and handling, and wouldn't hesitate to recommend it to anyone else until Konis finally comes out with a front strut fitment for the Focus/Focus ST.
Joined the dark side.
Zillon is offline
