Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HID on third gen focus, WITH DRL
Old 01-22-2013, 07:29 AM   #6
ad1das
Fan#: 108623
What I Drive: 2013 Sterling Grey 4d
FF Reputation: 1 ad1das Good Standing Member
Originally Posted by klotche View Post
actually, relay harness only allow you to avoid flickering, because mk3 focus receives 9 volt power on DRL..
the ressitor are the things that make you avoid the "dipped beam bulb" - the error
With those resistor in parallele, your computer thinks you have incandescent bulb of 55 watt (original) plugged to it.. relay harness alone isn't enough to imitate the incandescent bulb resistance
Thank you for correcting that. That is what i meant, i was just beyond tired. I had to tuck the resistors away because they get super hott, but they are all a part of that harness. I picked it up on ebay for 13 bucks, and it was the exact same one that my shop uses and sells for 85 :/
2013 Focus SE Sedan
- Eibach Sportlines, K&N, MS3 RMM, HIDs, All L.E.D's
2013 Oxford White FX4 F-150
ad1das is offline
