Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lowered and bumpstops
Old 01-22-2013, 07:19 AM   #2
Fan#: 108623
What I Drive: 2013 Sterling Grey 4d
FF Reputation: 1 ad1das Good Standing Member
So in my past experiences, mostly with mustangs, i end up cutting the stock bumpstop in half. I did this on my 2011 and it had full suspension done. It was also causing me not to be able to launch properly when at the track, since the car would hit the stock height bump stops.
I just recently added the Eibach sportlines to my 13 sedan, but i did not cut the rear bump stops yet. I want to see/hear how often they do bottom out, if at all, before cutting them.
Worst case is you buy new bump stops and swap them out with cut ones. You dont want to remove them completely because when you do bottom out, it will sound horrible and cause damage in the long run. Metal on metal contact is NO BUENO.
Those are my 2 cents.
2013 Focus SE Sedan
- Eibach Sportlines, K&N, MS3 RMM, HIDs, All L.E.D's
2013 Oxford White FX4 F-150
ad1das is offline
