Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - quick question
Thread: quick question
Old 01-22-2013, 02:18 AM   #11
Duhamel
Duhamel's Avatar
Fan#: 78883
What I Drive: Black '14 Ti
Points 844, Level 15
Points: 844, Level: 15 Points: 844, Level: 15 Points: 844, Level: 15
Level Up 44% Completed
FF Reputation: 1 Duhamel Good Standing Member
Baldurs,
Did you remove the grille from the full piece with the honeycomb/mesh part? As in, you only had the part with the two bars and logo to tend with? Just asking. All I used was cheap grey primer, 3 coats, and Dupli-color black, 3 coats, and put each coat on while the other was slightly tacky (5-10 minutes), which was after sanding the entire surface with 360 grit and wiping it with a tack/tacky cloth. The only issue is re-attaching the grille. I had to use 3m double-sided "tape". You can easily see the bolt that holds the logo on when you have it separated from the honeycomb/mesh part.
Mine's held up for over 8,000 miles/12,000 kms with barely any chipping, and it was chrome to begin with.
Edit - I also prepped and painted my fog bezels and chrome accent rings with the same process and color, which is holding up even better than the grille. I can't stand the flat black plastic crap.
Snorkel Delete / K&N E2993
Duhamel is offline
