Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Cranks but no Start
Old 01-21-2013, 09:55 PM   #2
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,640, Level 78
Points: 14,640, Level: 78 Points: 14,640, Level: 78 Points: 14,640, Level: 78
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 90 goinloco1 Excellent Standing Member
check the wiring to the coil. not just at the plug, but all the way down into the loom on top of the tranny. fought this with a friends, replaced the coil wiring pigtail ($14 through ford) and still couldnt get the thing to act right or start all the time, or even stay running. ended up the wiring for the coil pigtail was messed up further down in the loom by about 5" than we had spliced.
first check your voltage at the plug and jiggle the wiring around to see if there is anything. if you don;t have voltage check the usual culprits first,,, fuses, etc. then start hunting down wiring.
goinloco1 is offline
