Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - bad svt problems!!!HELPPP
Old 01-21-2013, 08:09 PM   #10
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 39,119, Level 100
Points: 39,119, Level: 100 Points: 39,119, Level: 100 Points: 39,119, Level: 100
FF Reputation: 35 tukaniSVT Great Standing Member
did you check the Cat?? I read you checked the VCT Solenoid, but the people here are suggesting you check your Cat.
Maybe, you should check that. Take it a muffler shop if you want them to check it.
Or if you have an OBDII Reader, unplug your cat and run your car for a couple of minutes. IT WILL BE LOUD ... but if the headers don't turn red, and all you get is the 2nd O2 sensor issue, then it's your cat.
And the code for the O2 sensor would be because you would be doing this test with out the cat in.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
