Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - High Idle Saga Continues...
Old 01-21-2013, 06:47 PM   #6
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,640, Level 78
Points: 14,640, Level: 78 Points: 14,640, Level: 78 Points: 14,640, Level: 78
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 90 goinloco1 Excellent Standing Member
sorry, I should have made it clearer that was meant for eklipse who started having the idle problem after loading a tune.
Originally Posted by rycodge View Post
I believe my throttle body butterfly is completely closed. I was under the assumption this was normal and the idle is completely regulated by the IAC valve. You're saying I should adjust the idle screw until there is a bit of a gap (1/8th inch)? I have no idea what the previous owners have done to the car, but you're saying if the butterfly is completely closed it will force the ECU to run in a "high idle mode" to compensate for the closed butterfly? This might make some sense because again, with the IAC valve disconnected the car revs and idles normally.
Is there any documentation available on adjusting the TB butterfly?
Also, if an injector o-ring was leaking, wouldn't there be a hint of gas smell in the engine compartment. I have not detected the faintest hint of a gas smell while working on the engine.
goinloco1 is offline
