Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 08 focus headlight problem
Old 01-21-2013, 06:12 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
get a meter and test the harness to see if it has power going in it when turned on. did you touch the bulb itself when you took it out or put it back? the oils on your hands can cause the bulbs to overheat and blow. as far as aiming did you get the bulb put back in properly and locked in place? they are easy to put in off center or not locked in all the way and look as yours does. could have also been that something was hit while removing.
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
