Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - For Sale: Trunk and hatch LED conversion kits
Old 01-21-2013, 12:38 PM   #4
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
FF Reputation: 7 VonKrause Good Standing Member
Buy-Sell-Trade Rating: (3)
I have yet to sell the 3 setup, but there are a couple setups we can do, one on the left side behind the sub and then two on the right side. OR all three on the right side.
They mount under the plastic moldings that are on either side, they mount using double sided tape on the back of the LED bricks.
The power source is the outlet for the stock bulb. There are a couple things you can do, I have the adapter that plugs right into the bulb socket so all you have to do is remove the bulb and insert the wire plug, or you can splice into the bulb wire and place an LED wedge into the socket for more light. Both ways are pretty simple and don't require adding or modifying much.
Get your trunk or hatch LED conversion kits here
Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
