Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - For Sale: 98 Jeep TJ For Trade
Old 01-20-2013, 10:20 PM   #1
RPMisChris
RPMisChris's Avatar
Fan#: 76276
What I Drive: 07 svt 2.3 swap thing
Points 6,066, Level 50
Points: 6,066, Level: 50 Points: 6,066, Level: 50 Points: 6,066, Level: 50
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 1 RPMisChris Good Standing Member
Buy-Sell-Trade Rating: (16)
Price: Pref a straight trade or $6500
Contact: Chris via PM
1998 Jeep Wrangler. Clean title. Engine is a 4.0L straight 6. Manual 5 speed. 149K mi and running strong. Recent tune up with new sparks, hoses, wires, oil and fluids. Always well maintained, runs and drives like a beast! Built for offroad but recently adjusted for daily commuting.
Pros:
-4" Rough Country Suspension lift
-5 New (less than 1k mi) 33" GoodYear Wrangler tires
-Rear axle re-geared to 4.56 with yukon gears and new bearings
-5 Black American Racing wheels
- Steering Stabilizer
-Transfer case drop
- Newish U joints and slip yoke elim
- older Borla exhaust and header
-Throttle Body Spacer
- Sound Bar with new sony speakers
- HardTop
- Custom Halo Headlights
- Off road auxilary lights with interior switch
- Fully Functional Hood Scoop
- Hurst short shifter
- Soft Windows
- Custom LED Tails (flush mount)
- Volant Air intake
- 3 core Metal Radiator
- custom fit floor mats
- doors / bucket of the cab herculined
- New fender flares
- 1 yr old Sears Duralast gold battery
- Synthetic Transmission Fluid
- New slotted front discs / pads
- Custom Front Bumper
Cons:
- You will need to re-gear the front differential at 4.56 if you plan on using the 4wd. Like I said I needed to regear the rear to maximize drivability/ gas mileage as this jeep was unfortunately tasked with Daily Driving.
- There is a slight oil leak but this is normal with jeeps.
I replaced the oil pan gasket this last year and am thinking that the oil
pan is bent. The pan is only $100 and is 16 bolts to install. It also could be the rear main seal gasket which is like $20 and 16 bolts to install.
Most jeepers dont bother fixing this as it doesnt really leak much at all.
Links from other Jeepers who have the same issue:
http://www.wranglerforum.com/f5/98-t...ak-193770.html
http://www.pirate4x4.com/forum/newbi...leak-help.html
- Exterior Could use paint but it is an offroad Jeep
PICS:
RPMisChris is offline
