Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tune up ? What should i have done?
Old 01-20-2013, 01:51 PM   #12
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,294, Level 100
Points: 32,294, Level: 100 Points: 32,294, Level: 100 Points: 32,294, Level: 100
Forum Activity 4%
You don't have an owner's manual? The directions about how to test it are in there. It's easy, IIRC, you simply start the engine, allow it to idle, then press and hold down the button and check the reading on the gauge there under the hood. The button/gauge is right behind the driver's side headlight. Go check your owner's manual, it's under routine maintenance. I have seen where those filters were damaged and the filter filled up with leaves or water, but you'd know it because it wouldn't run right.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
