Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HELP! Engine Surging and Dying at Idle.
Old 01-19-2013, 06:11 PM   #5
Z3T3C
Fan#: 107116
What I Drive: 2000 SE Zetec with ATX
Points 134, Level 2
Points: 134, Level: 2 Points: 134, Level: 2 Points: 134, Level: 2
Level Up 68% Completed
FF Reputation: 1 Z3T3C Good Standing Member
Originally Posted by Classic6200 View Post
I had the exact same problem. The rubber vacuum hose that goes from under the throttle body assyemble to the side of the moter under the coil pack had sprung a leak. Only place to get the hose is from the dealer for around 40 bucks.
That would be one of the PCV hoses that I replaced yesterday when it came in from Ford. The other runs from the bottom of the air box to the top, driver's-side of the engine. The filter at the bottom of air box for that hose was full of oil and was disintegrating, so I replaced that too. I also forgot to mention in my original post that the PCV valve & air filter were just replaced in the process.
There is a bit of hesitation when you punch the gas at idle, but the engine doesn't buck when it gets up there in RPMs. However, it dies immediately after as it gets back down to idling speed. Fuel related?
Z3T3C is offline
