Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Should new tires go in the front or back? Discuss
Old 01-19-2013, 05:30 PM   #22
amc49
Fan#: 96610
Points 6,694, Level 53
Points: 6,694, Level: 53 Points: 6,694, Level: 53 Points: 6,694, Level: 53
Level Up 72% Completed
Forum Activity 100%
'...........the better gripping tires on the rear obviously increase the rear grip............'
This can actually bite you hard. If using the old tires on back, they will have a tendency to slide out at lower speeds, possibly alerting someone to a problem. The new tires will hold better then break loose at a faster speed from higher forces, a much more dangerous situation since at higher speeds, rarer and more unexpected. A car that slides out easier forces one to be a better driver unless he is an idiot. Refer to driving on ice........
amc49 is offline
