Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Restart issue after timing belt replacement
Old 01-19-2013, 03:18 PM   #6
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Well, you know the timing is set right. Put the rest of it back together. you need to bleed the cooling system anyway.
Can you physically hear the pump operating?
That's correct though, there is no pressure test fitting. The little "regulator" you see on the end of the rail is simply a pressure sensor so the computer can adjust the pump's output.
Also, are you sure someone didn't siphon out the gas?
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
