Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Restart issue after timing belt replacement
Old 01-19-2013, 04:02 PM   #5
biederboat
Fan#: 9840
What I Drive: 2000 ZTS
Points 1,235, Level 19
Points: 1,235, Level: 19 Points: 1,235, Level: 19 Points: 1,235, Level: 19
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 biederboat Good Standing Member
Okay, so there doesn't appear to be any way to hook up a fuel pressure gauge on a Focus? I can't find any test port on the rail (2000 Ztec).
But I did remove the fuel fitting from the rail, turned ignition on: nothing. Cranked over and it started for a bit, I suspect it was able to suck fuel in that was otherwise held back by having had the line sucked dry.
I checked the fuel pressure switch again. Is there any reason that it wouldn't pump fuel just because the alternator is disconnnected? I still just have it running with the timing belt, not the accessory belt.
BB
biederboat is offline
