Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tune up ? What should i have done?
Old 01-19-2013, 10:53 AM   #5
Dukttape
Dukttape's Avatar
Fan#: 94135
What I Drive: 2011 Sangria Red SE Sedan "Fiona"
Points 714, Level 14
Points: 714, Level: 14 Points: 714, Level: 14 Points: 714, Level: 14
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 1 Dukttape Good Standing Member
Also grab yourself a bleeder kit and do your brake/clutch fluid. I'll be rolling on 30k here in the next month and I'm going to be doing oil, tranny fluid, and I'm buying a motive power bleeder from FSWerks and going to start doing the brake/clutch fluid every spring. I'm also putting in magnetic oil drain plug and this fall a bypass filter system in, which gives 2 oil accesses ports to run temp and pressure gauges , and I figure more filtering is a good thing for a DD.
Roush performance intake, Exedy 12.5 lb flywheel, Massive 76A lower engine mount... more to come with more money.
Dukttape is offline
