Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Power Steering Issues
Old 01-18-2013, 12:38 PM   #6
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 3,144, Level 34
Points: 3,144, Level: 34 Points: 3,144, Level: 34 Points: 3,144, Level: 34
Level Up 63% Completed
Level up: 63% Level up: 63% Level up: 63%
FF Reputation: 18 elsolo Great Standing Member
You want the specific pressure hose from Ford or equivalent. Check Rockauto.com. I remember a thread not too long ago here where a member made a braided stainless power steering hose, it should have worked fine but there was no steering assist at low speed.
The pressure switch is on that hose, but a separate part number.
There is also an O-ring you'll need for the fitting end.
The supply hose could go generic, but with all the weird bends in the hose, I would go Ford or OEM equivalent. That hose has no pressure, just a gravity drain to the pump inlet.
elsolo is offline
