Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - TPS at idle
Thread: TPS at idle
Old 01-18-2013, 12:04 AM   #4
amc49
Fan#: 96610
Points 6,932, Level 54
Points: 6,932, Level: 54 Points: 6,932, Level: 54 Points: 6,932, Level: 54
Level Up 91% Completed
Forum Activity 100%
ECM actually recalibrates when you change TPS based on the high and low voltages the new one shows, i.e., it does not expect an EXACT match, just close................I get a high % (actually around 19 or so just like yours!) on my scanner too, but in my case it means nothing since both cars run perfect. When I first saw that I thought about it, but time has rendered the point moot. Check the voltage range with VOM and compare to the average numbers given as acceptable. Voltage more important than % since every device can interpret % differently.
amc49 is online now
