Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford's letter regarding the "PowerShift 6 Speed Operating Characteristics"
Old 01-17-2013, 09:42 PM   #10
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 10,531, Level 68
Points: 10,531, Level: 68 Points: 10,531, Level: 68 Points: 10,531, Level: 68
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
FF Reputation: 7 Red Jay 918 Good Standing Member
The 6F35 is less efficient, having a fluid coupling (torque converter) and lots of hydraulics. The dry dual clutch Powershift DCT is lighter, simpler, and more efficient when it is functioning properly having been based on a pair of three speed manual transmissions sharing a single transmission case and actuated using servo motors for the gear selection and the clutch actuation.
Personally as long as the DCT works correctly I prefer it over even over a properly working 6F35.
I don't like how the 6F35 operates. The constant locking and unlocking of the torque converter while trying to maintain speed on the freeway, and the fact that it won't shift to 6th before 41 mph in every 2.5 or 3.0L Fusion I'd driven.
It was merely adequate with the 1.6 L ecoBoost in the Escape, but I am not sold on its long term longevity even more so than the DCT. Ford has never really built a great fwd torque converter backed planetary automatic transmission, certainly none of the products to come from the Van Dyke Assembly plant have held up that well. Although in some cases that's due to the prior owners not maintaining them at intervals much more frequently than recommended by the owners guide or the service manual. The AX4N/4F50N tended to implode some point just past 100,000 miles without fail.
was kinda thinking more of the 2013+ Fusions but then again i do mean Fusion in general.... assuming the 2.5L transmission would bolt up to the current direct injected D20. or does the 2013+ use the same transmission as the 10-12?
Red Jay 918 is offline
