Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Driving at night, odometer LED flashes lightly..alt?
Old 01-17-2013, 12:55 PM   #4
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,524, Level 100
Points: 30,524, Level: 100 Points: 30,524, Level: 100 Points: 30,524, Level: 100
Forum Activity 100%
FF Reputation: 128 sailor Excellent Standing Member sailor Excellent Standing Member
Well, that's not a good thing......
Things to start with:
Get the code read. (free at many parts stores)
Check the voltage with a meter, sometimes having it hooked up while driving helps with diagnosis....
Check idle RPM - low or fluctuating idle CAN be an issue, you don't want to chase charging problems if you actually have an idle rpm issue....
Luck!
(get back with results, someone will make better guesses from the info. you get...)
sailor is offline
