Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Installed new Oil Pressure Switch (2000 ZX3) still leaking oil ...
Old 01-17-2013, 12:01 PM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,096, Level 77
Points: 14,096, Level: 77 Points: 14,096, Level: 77 Points: 14,096, Level: 77
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
You have some good oil pressure! :-) Try the tape, make sure its only on the threads and only slightly over 1 wrap you dont want to much since I believe it is a tapered fitting. I used PTFE paste (but my motor has no oil in it), but you need to make sure its able to cure. some of that stuff requires air to cure, and if you only put it on the front few threads it may never cure. they do make special stuff that will cure when only in the presence or oil.
Magus2727 is online now
