Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - My '00 ZX3 overheated and is now running rough
Old 01-17-2013, 01:09 AM   #2
amc49
Fan#: 96610
Points 6,439, Level 52
Points: 6,439, Level: 52 Points: 6,439, Level: 52 Points: 6,439, Level: 52
Level Up 45% Completed
Forum Activity 100%
Depends on how long you drove with it overheating, was it out of water? If all the bad running started then, well, you may have toasted it. The sputtering could easily be a blown head gasket...............
If the oil leak not horrible, then change just plugs for a short term check, dirty plugs can miss, the overheat may have cooked the oil to short the plugs. Save the valve cover gasket until sure the motor's still good.
I'd be looking into the check engine light..........
luck.
amc49 is offline
