Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Special Tool Required for Brake Master Cylinder Replacement?
Old 01-16-2013, 11:23 PM   #7
amc49
Fan#: 96610
Points 6,926, Level 54
Points: 6,926, Level: 54 Points: 6,926, Level: 54 Points: 6,926, Level: 54
Level Up 88% Completed
Forum Activity 100%
Unless the ABS was activated during low fluid and swallowed air (should be impossible, but somehow people figure out how to do it!), then it is transparent to the system and normal bleeding should work fine. I would AVOID powering it on during bleeding if possible, only do it when necessary or forced............I know I never do anything special for it. Once you get air inside the ABS itself you are in much more trouble from what I've seen.
amc49 is online now
