Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any interest in headlight modifications?
Old 01-16-2013, 06:20 PM   #191
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,434, Level 21
Points: 1,434, Level: 21 Points: 1,434, Level: 21 Points: 1,434, Level: 21
Level Up 34% Completed
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by JL330 View Post
I royally messed up the last set of headlights I put in the oven. One of the lenses melted a little and both of them ended up looking etched really bad. That oven may have run hotter than it should though.
It should only be on warm which is maybe 250 degrees.
Originally Posted by e30og View Post
Someone correct me if Im wrong, but condensation just means either a crack somewhere or some part of the edges glued together isnt 100% sealed, right? As long as you really get the pieces glued together well, there should be no issue?
Also Chickenmuffin did this with a heat gun, which wont heat the entire lens. Here is his writeup:
How to: Bi-Xenon Projector Retrofit
Ya it just means it's not perfectly sealed. Do not use a heat gun, you risk cracking the lens when pulling it apart due to the uneven heat distribution.
thejordan is offline
